Ir para o conteúdo principal
O ZTE Max XL é o modelo topo de linha dos celulares da ZTE. Ele possui uma tela sensível ao toque de 6" e uma bateria de 3990 mAh.
Phone will not charge
My cell phone will go into charging mode but it decreases the battery percentage and reads as a USB corb but it is plugged into the wall can u please help me?I've soft reset it, wipe cache everything nothing is working was working last night
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I believe this is a battery issue. Which should be cheap
I have the same problem. I found i way to turn boot the phone still though. I just have to stick a pin or similar thing in a little space in the back of the phone and hold it there for about 3 seconds and the phone will be booted. To wake the screen i just downloaded an app where i can use the power button to wake it and also downloaded an app where i can use the sensor beside to front camera to wake it.
Or charger port, which is daughter board
http://www.ebay.com/p/2x-zte-max-xl-n956...
Can't seem to find proper guide
Desmontagem do ZTE ZMax Pro (Z981)
Or it's charging circuit and requires microsoldering. Not for beginners
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Irisht-raw 94 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 19
Ao todo: 9,002
