Ir para o conteúdo principal
Comprehensive set of repair and troubleshooting guides for Nintendo game consoles played on the TV since 1977.
911 Perguntas Visualizar todos
Squeaky tray and door
My grandparents recently found an old NES and they decided to give it to me. However, both the door flap and the tray are very squeaky and I was wondering if there was a way to fix that. Everything on the NES works normally, but the squeaking kinda hurts my ears.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi!
I think there is a way to fix this. Just follow this guide to remove the cartridge tray from the system. Then use some WD40 to lubricate the moving parts. Make sure you give it enough time to dry out a bit and wipe any excess fluid carefully with alcohol.
Do the same thing to the hinge of the door flap, just be careful not to spill WD40 on the main board or on any other electrical parts. If you do, wipe it with alcohol as fast as possible.
Esta resposta foi útil?
Pontuação 2
Dont Worry, both of mine have that too. It wont affect your console at all.
Pontuação 1
1 comentário:
The thing is do you really want it to sound like that??
por
Adicionar a sua resposta
Loopida será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 548
