Ir para o conteúdo principal
Informações de reparo para os fones de ouvido Crusher Wireless. Número do modelo: S6CRW-K591. Disponíveis pela primeira vez na Amazon em agosto de 2016.
Bass lever not working
Imagem
Not be confused these are NOT the original crusher headphones.
The bass lever on the left ear cup is not working. I tried taking it apart to look at the circuit board but everything looks perfect from the inside.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
I had this problem when I first got my pair as well. First of all, make sure the headphones are charged and that you are using the charger that came with the headphones if you are charging it for the first time. Then to fix the problem hold the power button (left side above slider) and the volume up button (top-right) at the same time for about 10 seconds, this will shut down the headphones completely without the voice saying “power off”. Then turn them back on and while listening to something, start moving the bass slider up and down and it should work again after a couple seconds
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
warrenspottedeagle será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 32
Ao todo: 2,264
