Ir para o conteúdo principal
O HTC Desire é o primeiro smartphone da série Desire desenvolvido pela HTC.
I dont know what happened ...
when i turn on my phone it keeps repeating the welcome window repeatedly.....
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Phone is on but no picture no service
por Compartilhar
Adicionar um comentário
3 respostas
Solução escolhida
rica, did anything happen to the phone? Any firmware or software updates? Anyhow try this first and see what happens. Hold the Volume - button then press the power button once. You should boot into FASTBOOT. Select BOOTLOADER, and select clear data or something like that. This will do a factory reset for your phone. You may lose your info on there so make sure you have some sort of back up for contacts etc. http://www.htc.com/europe/howto.aspx?id=... and here http://www.knowyourcell.com/htc/htc-desi... is more info Let us know if this helped so we can continue to assist you if not. Good luck.
Esta resposta foi útil?
Pontuação 1
I had the same problem, and after days of searching on internet I realized the problem is the overheating of the CPU which is a hardware problem. Maybe you guys can fix the problem. Good luck
Pontuação 0
i was restoring the factory setting and during restoring it become dead . i dont know wht happend . can anyone help me to resolve it .????
Pontuação 0
Adicionar a sua resposta
rica será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 5,414
