Ir para o conteúdo principal
Sony’s 20.1 megapixel camera designed to capture still images and video recording up to 720 pixels.
transfer photos to computer using windows xp
I had to pull out an old computer using windows xp. Is there any way to transfer the photos from my DSC-W830 to it? Nothing I try seems to work and I can not find any programs to download that willl help. Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
You won't need any programs. The operation is simple.
  1. Take out the SD card and put it into the computer. You will need a SD card or Memory stick reader.
  2. Open windows explorer.
  3. Open the SD card or Memory Stick from there. You'll have to find the correct one.
  4. Drag the photos out of that folder then put them where you wish, probably in the pictures folder.
Hope this helps!
Esta resposta foi útil?
Pontuação 2
11 comentários:
Welcome back!
por
Unfortunately this dinosaur does not show explorer ANYWHERE. I am able to insert the card directly into the computer. The little green light comes on but then ... Nothing :( Thanks for trying. I'm fairly computer savvy but this has me stumped.
por
TaQu, Click on Start, then Run, and enter in a folder name, like “C:”, and click OK – that should open up Windows Explorer.
por
George, I miss typed ... that was one of the first things I did. A bit differently but same result. I should have said the card doesn't show up ANYWHERE. I'm sure it is not your advice, it's something wrong with the computer itself. Like I previously stated, I am able to insert the card directly into the computer. The little green light comes on but then ... Nothing . Thanks again for your input.
por
Exibir mais 6 comentários
You need a card reader,then insert the microSD card,then copy the photos on your computer.
The normal way to transfer your photos is to pop the SD card , put it in an adapter and put that in your computer to copy the photo across.
Pontuação 0
This Coolmuster Android Assistant, which can remove the limitation of accessing Android internal memory and enable users to backup everything not only from SD card, but also from internal phone memory to PC or Mac computer directly.
Pontuação 0
Adicionar a sua resposta
TaQu será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Ao todo: 635
