Ir para o conteúdo principal
O smartphone Android Sony Xperia Z5 foi lançado em outubro de 2015. O Sony Xperia Z5 possui uma tela de 5,2 polegadas com 1080 x 1920 pixels, equipado com um processador Qualcomm Snapdragon 810, 3 GB de RAM e uma câmera traseira de 23 MP.
While calling phone screen turns off?
While using any calling feature (phone, facebook, etc) my phone screen goes black and won't turn back on, if the other person doesn't hang up first than I have to manually restart my device to end a call. How do I fix this? Seems to only have started after I installed Nougat 7.1.1.
Esta é uma boa pergunta?
Pontuação 5
1 comentário
can i turn off that sensor that make the screen black when covered ?
por
Adicionar um comentário
6 respostas
Pergunta mais útil
Do you have a screen protector or a case that may be covering up the proximity sensor? If not, the proximity sensor itself may need cleaning or replacement.
Esta resposta foi útil?
Pontuação 3
1 comentário:
I had this problem and it was annoying, especially when I had to press the dial pad to go to different services from the number I was calling. So I googled it many times and had all these long winded methods. Then I got a post from a bloke that sounded like he was Russian. When making a phone call and your phone goes blank, just press with you finger in the right hand top corner and the screen comes on again. Thankyou Komrade.
por
Make phone call. When screen goes blank, press right hand top corner of screen.
Screens comes on again.
Pontuação 2
3 comentários:
Thanks for this very helpful information
por
Omg it works thank you!!!
por
2023 still using this trick. Tq very much
por
I have that problem also
Pontuação 0
Well Ensure that the proximity sensor is not being blocked by foreign objects, a screen protector, or a protective case.
Following might be helpful for you: https://wethegeek.com/how-to-fix-android...
Pontuação 0
Hi, there is 2 type of problem, first clean your sensor, usually top left of mobile phones, Second may your proximity sensor need to be replace.
Pontuação 0
i just pressed the top righthand corner and the screen came on !!!** weird or what
Pontuação 0
Adicionar a sua resposta
Char Duffett será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 12,145
