Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
20 Perguntas Visualizar todos
Error 1015 on itunes at restore.
When I connect my iPhone 3GS to iTunes, it shows error 1015, and I can't restored it. Please help me!
I have iOS 4.1.2.
Esta é uma boa pergunta?
Pontuação 28
2 comentários
how to fix error 1015 in iphon 3gs
por
have you tried any of the suggestions above?
por
Adicionar um comentário
21 respostas
Pergunta mais útil
You can also fix error 1015 by following this guide:
http://blackbox-iphone.com/index.php/how...
Esta resposta foi útil?
Pontuação 4
1 comentário:
mac users is wrong..it's in utilities, terminal..you need to fix your website..
por
There is a guide out on http://modmyi.com/forums/3g-s-downgradin... that shows how to handle this error. If you follow this forum and check on user Odalis, you'll see that he has a perfect description as well as software posted to assist you with the solution to this error. It may require you to sign on the forum—but it's free, and you will find plenty of further information on those forums.
This page has Apple's answer to your problem, using a Mac. Here is more info for Mac and XP. This final solution is for Mac only. I hope that this will guide you in the right direction. Good Luck
Pontuação 3
5 comentários:
i have mac os x, not windows.. with those solutions i can't restore it anyway
por
My sincere apologies. I always forget about the Mac. Anyhow here is Apple's answer to your problem http://support.apple.com/kb/TS1275 and it does have the Mac listed and here is more info for Mac and XP http://www.redmondpie.com/fix-itunes-100... the final one is for Mac only http://blackra1n.org/2010/03/resolve-err... hope that this will guide you in the right direction. sorry I did not get it right the first time ;)
por
i can't restore it anyway, i'm being crazy now, i don't know what is the solution..
por
Keep trying there are probably many many more ways to fix it. We will all try and help you.
por
Try this and it could help to fix iTunes error 1015 on older iPhone.
por
This always fixed that stupid 1015 error for me http://howtofixstuff.blogspot.com/2012/0...
Pontuação 1
iTunes error 1015 is always along with the "plug into iTunes" screen stuck on iPhone. Indeed, that is the common error "iPhone stuck on recovery mode". Easy and quick way to fix it is to use the ReiBoot. Have a try by following this guide: How to exit iPhone recovery mode easily and quickly.
Pontuação 1
http://www.allaboutappleblog.com/2013/11... I hope it will help you out
Pontuação 1
You can use and app like 3uTools to make your iPhone work.
Pontuação 1
i plugged my iphone 3gs 32gb to itune and it said something like, "the new version of the iphone software is available". i downloaded it and when the download was done, my iphone restarted and the screen got stuck in the itune plug in. i restored it but itune says can not restore, error 1015...i tried IREB to fix it but it still shows the same error. PLEASE somebody tell me how to fix it...by the way, my iphone was jailbroken before the incident happened.
plz help me....thanks
Pontuação 0
2 comentários:
If you've got tinyumbrella you cam use that to boot out of recovery using your saved shah blobs. The error is that iTunes recognises a corrupt version of it's ios and will not complete signing.
You need to download a "clean" version of the ios you want... For example download from ericbruin or iclarified or uninstall iTunes and reinstall(save all your stuff somewhere safe and the put back in library after you've done a clean install) you can try going to a friend and using their iTunes... This sets up a new iPhone and apple will then send a fresh install instead of trying to load your corrupt version. Please start your own question
por
TinnyUmbrella will not fix the issue.
por
how can you fix the error 1015 and update
Pontuação 0
I have had this issue just recently and have tried everything possible to fix it. I've come to the conclusion there is no way to fix the problem, TinyUmbrella doesn't work, you will just get more errors with that program. IRev doesn't work, same thing more errors. None of the videos on YouTube have the answer (most are for Windows users). The only solution is to take it to a tech shop and get them to restore it for you. It will cost $60-$100 bucks and then you have to restore your service provider which will cost you another pile of money etc etc etc. :( Not the answer you where looking for.
Pontuação 0
plz help i can not fixmy problem 1015
Pontuação 0
no farmate and no restore
Pontuação 0
my phone is not update this moment
Pontuação 0
It appears that despite receiving this error the OS did in fact restore. What worked for me personally was downloading Bootrec (which kicks it out of the recovery loop) and back onto the Home Screen.
Pontuação 0
itunes is a load of rubbish they dont want you to do anything for free, if the did they would use the file explorer to move files. I am having trouble with my iphone 3g,it iwas stuck on the apple logo then i went on youtube, looked for a solution, and it told me to restore my iphne. so i did then once itunes had finished that, it came up with error 1015,and was then stuck in recovery mode. i was then looking for, how to fix an iphone 3g stuck in recovery mode and it told me todo the same thing,once itunes had finished that it came up with another error mesage saying error 3194.
what a waste of £150 when itunes wont let me restore my iphone. i would advise anyone to stick to android or windows if this problem cant be fixed.
Pontuação 0
yes
Pontuação 0
1015error iphone 3G
Pontuação 0
i can not restore my iphone 3g 4.1 on itunes
and iphone shows the error 1015
how can i install software in my iphone 3g
please help mee!!!!!
Pontuação 0
1 comentário:
the ispot is your last hope :\
por
Error 1015 Iphone 3GS?
Pontuação 0
iphone 3G errors 1510
Pontuação 0
יש לי שגיאה 1015 איך אני פותר את זה
Pontuação 0
what your all family name nd your full name
Pontuação 0
Adicionar a sua resposta
chapepe será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 156,666
