How do I change the motor mounts?
The engine vibrates when I accelerate. When I change gears, the engine moves a lot.
Esta é uma boa pergunta?
@rjasonford not quite convinced that this is caused by the motor mounts. I attached the Engine Removal part of the SM with this answer. That manual shows the mounts and how to pull the engine to replace those. Not an easy job.I would suggest that you check the motor and transmission mounts first. Also, rule out engine performance issues (fuel delivery, emission control etc. ) and check your vacuum hoses etc. Honda CRV Engine removal
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 1,161
Did motor mounts fix this? Kcnoblitt@yahoo.com
por Kenneth Noblitt
