Ir para o conteúdo principal
The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
when installing new battery the horn sounds. how to stop this?
As soon as the system gets electricity, the horn sounds in an off and on pattern. How can I stop this and install the battery. Alternatively, where is the horn wire to disconnect it?
Esta é uma boa pergunta?
Pontuação 2
2 comentários
I am putting new battery in car . When i connect horn goes off won't
por
Check if you are connecting the correct battery terminals.
por
Adicionar um comentário
2 respostas
Solução escolhida
Answering my own question: Hook up the battery, then use the remote (car alarm button) to turn off the horn.
Esta resposta foi útil?
Pontuação 2
1 comentário:
What if you don't have a key fob
por
If the beeping persists because your key fob does not work or has a low battery itself, endure the beep until you can start the engine of your vehicle.
Pontuação 2
2 comentários:
Even when I get the car running thorn keeps beeping! Now what?
por
Start the car, put in reverse, drive and shut off the engine.
por
Adicionar a sua resposta
TWB será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 14
Últimos 30 dias: 38
Ao todo: 27,385
