Ir para o conteúdo principal
The Samsung Captivate is a USA-exclusive flagship Android phone in the Galaxy S class of devices, released by Samsung in March 2010 for use on the AT&T network. Identifiable by model number SGH-I897.
13 Perguntas Visualizar todos
Micro USB port not connecting to my PC.
The pins in my Samsung Captivate have bent inside the port and broken off from normal use. Now the phone charges slowly and isn't recognized by my PC at all. Therefore, I can no longer transfer media, backup, or enter download mode to flash with Odin. Any information or help with this would be greatly appreciated.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
http://www.globaldirectparts.com/Samsung... has most of the parts that you might need and I would think that your problems are related to the bend/broken pins and should be resolved when you replace the broken porT and here is more info about your phone and its issues. Good luck
Esta resposta foi útil?
Pontuação 0
Adding to the previous answer, you can see the Samsung Captivate Motherboard Replacement guide to learn how to disassemble the phone down to the motherboard.
Pontuação 0
With most of the new Samsung USB ports they look much different than the others and have 7 pins as apposed to 5 which is another factor. To throw a wrench into the mix there are now many sellers offering these on eBay but there is a standard mount style and reverse meaning it will be flipped over with the side with more surface area against the logic board. I don't know why they don't seem to catch on but MOST of the sellers on eBay have it wrong. Here is a seller I KNOW and have dealt with before and I can tell you for sure this link is to the correct one on eBay. Keep in mind even if the picture is correct they might just be using a picture from the other along with the wrong info. If you need a port for a captivate and any tools like Torx kits here is the link you want. The item # is USB813 BTW.
http://www.ebay.com/itm/Micro-USB-Chargi...
Hope this helps somebody.
Richard
Pontuação 0
Adicionar a sua resposta
Spencer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 4,603
