Ir para o conteúdo principal
Este produto é um monitor LED de 27 polegadas com uma resolução de 2560x1440 pixels lançado pela Apple em 27 de julho de 2010. O seu número de modelo é A1316.
Possible Power Supply issue?
Hello everyone. Long time lurker, first time question asker. This community has been great to me over the years. I mostly replace iPhone screens and other easily addressed issues on iPhone for family and close friends of family. So this community has been very helpful with some of those things.
I recently was given a 27in Cinema Display from a customer of mine (from my actual job). He was about to throw it out because "it's just a black screen". I told him I'd take it off his hands. I was originally thinking it was just the back light that may be broken. However, after getting it home it seems like a possibly power supply issue. When the monitor is plugged into a power outlet it won't even power up a Macbook through the Magsafe cable. This is my first Apple display and it doesn't have a power button so I assume it just powers on when plugged in or when a device is connected to it?
For those of you out there that have repaired these, is the power supply a likely culprit? I'm getting 120v on the cable so that doesn't seem like an issue. I've read in a few places those can go bad.
Also, Macbook does not recognize a display connected. Thus another piece of evidence leading me to think the dang thing isn't even powering on.
Esta é uma boa pergunta?
Pontuação 0
5 comentários
Did you eventually repair the unit and was it the power supply? I have the exact same model with the same fault.
por
Did you even fix this? Just ran into the same issue with mine,
por
Hello , I am fixing up one for myself.
did you end up fixing this?
mine doesn’t power up the screen but when magsafe power cord connected to MBP it turns green light .
but NO responds on (USB sticks).
por
Hello, could you solve this ?! having the same issue (there is also a flash to the screen, like an attempt to display, when I first plug the display port on my macbook pro, but then nothing)
por
Power supplies tend to go. I'm very certain replacing it will solve your problem.
por
Adicionar um comentário
5 respostas
Solução escolhida
Look on the bottom of the stand to verify that it's an A1316
Looks like China is clearing this inventory out at cheap prices. Here's a brand new one at a great price.
250W Power Supply 614-0487 PA-3251-3A For iMac 27" A1316 LED Cinema Display
http://www.ebay.com/itm/New-250W-Power-S...
At that price, I'm getting one for stock.
Imagem
Esta resposta foi útil?
Pontuação 4
5 comentários:
Definitely an A1316. Sounds like you concur it's most likely a power supply issue?
por
Well when said that it wouldn't power up, that was a major clue ;-) Also, if the part doesn't work you can relist on eBay after they run out in China for double to triple your cost. Not a bad ROI.
por
haha. Well, I've been reading places that the AIO cable can cause power issues and is a common failure on this thing. I'll be ordering a board momentarily. Thanks!
por
Doesn't sound like a bad idea!
por
Please leave me one ;-)
por
For all of you curious, yes the power supply did fix my issue. It is still running strong today without any issues. It looks like the prices of the boards fluctuate tremendously and it seems I may have gotten lucky
Pontuação 2
1 comentário:
Yes I am waiting for one's price to come down from $120 to sub $100.
On Ebay in MAY 2019 sold one for $60. NOW June 2019 price gone back up to $120 + postage.
I am just worry that I buy one for $120 + postage then finds out POWER Board is NOT the my issue...
do I take gamble on this?
por
Any luck fixing this? I have the same display and now there is no power. Tried different cords, but no luck...
Pontuação 0
4 comentários:
I just checked with that supplier and the price went from $43 when I posted this to $90 as of 11/1/17
por
Thanks mayer. Is there a way to figure out if it's my power supply and/or the AIO cable I'm having issues with? I have tried to charge both a MB air and MB pro(with and without adapter). Wonder if I should replace both. A diagnostic from a retailer is of course and option, but if there's an easier way, I would prefer it. Thanks:)
por
Pål- Robin Hagen get in there with a multimeter and test the output side of the PSU. Look for expanded and/or leaking capacitors.
por
mayer, Ok, will give it a try. Thanks so much!
por
The replacement power unit seems to be available from a number of sellers on aliexpress as of early 2021, in the neighborhood of $65-80 including shipping.
Just do a search for: 661-6048
Pontuação 0
Anyone knows if Voltage reading on the Power Supply board like 25.4V where it says 24V can be a symptom of faulty board? ( on all the other pins reading is quite close to what it says only like 0.2 or 0.4 more than it says on board)
Pontuação 0
Adicionar a sua resposta
Jared Guthrie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 38
Ao todo: 12,228
