Ir para o conteúdo principal
Lançado em 28 de julho de 2017, o New Nintendo 2DS XL é um remodelamento tecnologicamente aprimorado do portátil 2DS. É o nono e último redesenho da linha Nintendo DS. O console é muito maior que o modelo 2DS original e adiciona todos os recursos da linha atualizada de sistemas "New 3DS", menos a capacidade de reproduzir jogos em 3D estereoscópico na tela superior.
How do I replace the Bottom screen and Top Screen
Hi, someone through my bag, and it dropped onto a tree stump. Both of the screens are damaged on my 2ds xl, the top one has lines going through it and the bottom touch screen is fully smashed, and won't work at all. Everything else works fine, the controls, speakers and all that but I just want to know weather it would be better to buy a new one, or to repair the one I have already.
Thanks and Cheers of all of you who have an answer to this problem
Esta é uma boa pergunta?
Pontuação 3
4 comentários
I have a problem like this,the bottom screen of my 2ds Xl is not functioning due to a dent and scratches. I'm only a kid so no money,how do I fix the bottom screen?
por
You’re gonna have to buy a replacement screen. Luckily, not too much. Probably $15-$30.
por
My bottom screen works fine but the top screen feel off do you no how to fix it?
por
So exactly the same thin as Liam but the top screen also I lost one of the connectors so I can not reattach the top screen do you know if I can get a replacement?
por
Adicionar um comentário
3 respostas
Solução escolhida
Hi!
While you can replace the bottom screen, the top one is, as @johnwp mentioned glued to the entire front panel.
You could follow this guide if you wish to fix your console yourself, you will only need a good source for the bottom LCD & digitizer and for the upper front panel. You could try AliExpress or eBay I guess.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Where would you find a replacement for the top screen? eBay has none for sale.
Thanks
JB
por
The top LCD is NOT glued to the entire top glass. There is adhesive around the paremeter of the LCD holding it to the glass. If you haven't actually taken it apart, please do not give people the wrong information.
Pontuação 3
I don't think the top screen can be easily replaced. The top screen is a whole unit. There is liquid between the plastic and LCD. If you take the LCD away from the plastic piece it will only further damage it. As far as I know the only course of action is to send it in to Nintendo. Can anyone verify this?
Pontuação 0
4 comentários:
Oh, my brother smashed my top screen while I was sleeping, I have CFW, can I send
it to Nintendo even though it is hacked, and how much will it cost?
por
If you can blindly navigate GodMode9, than you can uninstall CFW easily. It will cost $50 to send it to Nintendo, not including shipping.
por
Weird seeing SirNapkin here, also, I bought a new screen for $60
por
There is no liquid in between the plastic and the LCD, you cannot easily remove the LCD from the chasis without damaging it. But you only want to remove it when its damaged anyway. Can it be replaced, !&&* yeah it can
por
Adicionar a sua resposta
Recco waite será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 7,468
