Ir para o conteúdo principal
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
89 Perguntas Visualizar todos
Psp go wont turn on?
my psp is not working help
the other day my psp downloaded a game called beaterator and when i was playing the game it died, suddenly it wouldn't turn on after that and i was like "i will destroy you" so then i grabbed the usb cord and plugged it into a wall charger but it didn't charge, then i plugged it into the computer and nothing still! should i send it to Sony? :O i want to curse them out lol
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
3 respostas
Pergunta mais útil
Tommyrunsnaked, have you tried to:.
Try a hard-boot (Hold the Power button up for 10 Sec.)
Try to take out the battery and let it out for let me say 5 Min.
Connect the AC WITHOUT the battery and try to power on.
Let us know if this is working for you, if not we can try to find another solution for you. Good Luck
Esta resposta foi útil?
Pontuação 5
3 comentários:
it still didn't turn on
por
thanks :D:D !&&* yeah my psp turned on
por
My power button is broken. Can you tell me another way to switch it on
por
HI all i was having almost same problem...... I removed the battery and test without it. Now it is working. but if i put battery back it is not working again..... any suggestions
Pontuação 1
1 comentário:
Change your battery. Possibly its your battery that is shortening out the circuit....:-)
por
Hi, i Have a problem, i already tested with no battery and dont turn on, I think its the button on off its damage in the circuit, but my problem its where the energy in and out in the button in the circuit. Its charged the battery in psp and i test de battery and mesaure and its good. sometimes in the past the button failed when we turn on, doesnt work now, possible its the button on off. How i measure the button to see if its ok or not ok. Please help me . This Button have 4 pin and i dont now the direccion of the energy to mesaure or see if it are damage or shortening. Thank you for help.
Pontuação 0
Adicionar a sua resposta
Tommyrunsnaked será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 20
Últimos 30 dias: 86
Duração total: 22,032
