Ir para o conteúdo principal
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
opened dryer while running without hitting pause button
My mom opened the dryer while it was running without hitting the pause/cancel button now dryer wont turn on, the lights are flashing & its keeps beeping. I tried holding down both the start & off buttons but beeping still wont turn off & dryer wont turn on. How do I fix this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
@hawild unplug the unit from the outlet and let it sit for awhile. Then try again. Keeping it unplugged should reset it. you can also try to hold the "Drain/Spin" button and the "Start (Press & Hold)" button at the same time for no less than 3 seconds
Esta resposta foi útil?
Pontuação 1
2 comentários:
We tried that but it didn't work. Thanks
por
Okay so there is no change when you unplug it?
por
My dryer may be different from yours but i held the cancel button down for about 10 seconds. after that, the start button worked normally
Pontuação 1
Adicionar a sua resposta
Heidi Wild será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 1,173
