Ir para o conteúdo principal
Briggs & Stratton 190cc Model 120000 Quantum 675 Series Lawn Mower Engine. Released February 2011. For Toro 6.75 ft-lb torque Lawn Mower.
49 Perguntas Visualizar todos
My Toro self propelled lawn mower starts right up and then dies.
My engine starts up and runs for a few seconds and then dies. I've clean my carburetor and took the float bowl off and cleaned it out. The bowl had a small pieces of a gel substance in it. I removed the carb and the float bowl and blew them all out. Also took the float of and needle valve and blew out the carb. I've checked the fuel lines and no cracks. Put it back together and it does the same thing. Any suggestions??
Esta é uma boa pergunta?
Pontuação 0
4 comentários
This just happened to me today, and i've found another solution that has at least worked for me. I kept on pressing the fuel pump button for about 7-10 times every time before starting the lawn mower. The same thing kept on happening, the mower wouldnt run longer than a few seconds, but as i kept doing that eventually it started and now runs as a brand new one. It stayed in the garage for the whole winter so probably it got clogged cause of petrol that was left in the tank, but constantly trying to start it most likely unclogged it. Give it a try ;)
por
I have a Toro lawn mower, I prime it and it starts up and will mow a 15-20 foot strip and than dies. I prime it again , it starts and can mow a 15-20 foot strip and dies . I can do this over and over what is the problem
por
Same here!! I have tried all the fixes on YouTube...I have no idea what’s wrong but man it’s getting frustrated. Anyone have a fix?
por
Hey Tony, I just found this video. Not sure if it’s my problem or not but I haven’t seen anything like it yet. Hopefully it helps your situation. Going to try mine now.
https://youtu.be/xCzzKnX-sTQ
por
Adicionar um comentário
3 respostas
Solução escolhida
Problem solved. After removing the carb and pulling out the float and needle valve and using and air hose to blow it out, I put it back together and it did the same thing. I pulled of the bowl and the jet was clogged up. I blew it out and put the bowl back on and it now works good as new.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Try changing the spark plug
por
Pergunta mais útil
Starvation. See if this will give you an answer: https://www.youtube.com/watch?v=Gy--7hcB...
If it's a primer less one see this video: https://www.youtube.com/watch?v=UXztzNj0...
Pontuação 2
Another thing that can cause this is if the air filters haven't been cleaned in a long time. If they're clogged, the engine might not be getting enough air. Either clean or replace them.
Pontuação 0
1 comentário:
i have a toro gts comershall suzuki engine will run cut a 10 to 15 foot stripp stalls clenned card still stalls out
por
Adicionar a sua resposta
bobwid52 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 33
Últimos 7 dias: 241
Últimos 30 dias: 1,187
Duração total: 66,469
