Epson WF-3540 35mm plastic gearwheel broken bearing
A white plastic gearwheel is loose inside the printer, its 3mm black plastic bearing has broken off its chassis part. Please advise how to find a replacement chassis part.
The gearwheel is marked 1 AES >POM+PE<
The wheel is in the so-called rear cover assembly, place where plastic spigot bearing broke is clear to see even after I shaved it smooth. Plastic is about 4mm thick, not sure whether to try & tap it for 6BA thread or put a bolt through and nut behind, concerned it may impede paper moving on the other side. Surely fixable though.
Esta é uma boa pergunta?
2 comentários
@mach it is a very descriptive question, but unless we see what you are referring to, it will be difficult to identify. Post plenty of images with your question so we can see what you see. Use this guide Adicionar imagens a uma pergunta já existente for that
por oldturkey03
Thanks ot, this is one I didn't expect a fix for, just a seeking a source of Epson spares. I was given this dead printer and have not yet been inside to examine the broken bearing piece, just checked the printer will set up OK first. But if a spare is too hard to find or fit, I expect to smooth off the broken end, drill a 2mm hole and bolt on a 6mm long 3mm diam brass stud to replace the plastic one. If the base part is thick I could tap the hole, but if thin will need to get behind it to put a nut on the back.
Will post photos asap.
por David McGovern
