Ir para o conteúdo principal
Released on June 23, 1996, Model NUS-001, 64-bit gaming console
114 Perguntas Visualizar todos
It powers on but won`t work on my tv
I have tried it on all of the tv s in my house and I can`t get it to work. It works at my in-laws and it worked on a tv in my shop. That tv is now in my house and it does`nt work on it.I brought home a super nes and it works fine. Could my sattilite interfear? I`ve tried it on HD tvs and standard and the only thing thats changed on the one tv is being hooked up to my satilite.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta mais útil
Your 64 is run on the PAL (analogue ) factory set yo channel frequency 36, try tuning with the TV aerial NOT plugged in you may have co-channeling.
Esta resposta foi útil?
Pontuação 1
If the only difference is the satellite then why do not just disconnect everything else and hook the 64 up directly to your TV See if it works and then try to connect the other pieces back to see what interferes.
Pontuação 0
1 comentário:
I agree with OldTurkey03. If you have confirmed that the N64 actually works then it has to do with TV itself and the way you go about hooking it up.
por
U need a tv that's old as !@#$. It's sad but true. If that's not gonna work u could try modding it with a guide found everywhere on google.
Pontuação 0
3 comentários:
Not true. N64 works fine (with composite video) on my brand new HDTV. And composite video looks fine, i dont know why everyone says its so bad, its just fine.
por
You have a different tv than the rest of us, bud. I try these consoles out on the regular and it's rare I get one that reads on a newer tv, the situation being that the source detects the output but will not display.
por
@shaman32 what input does ur n64 work on?
por
Adicionar a sua resposta
Richard Colquitt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 7,491
