Ir para o conteúdo principal
Netbook de 2008; Modelo ZG5 AOA150-1691; tela de 8,5"; processador Intel Atom N270 de 1,6 GHz
No bootable device available
It says to insert disc and press a key it says
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @mmm813 , proceed to your acer bios, and check if the hard drive is detected.
Under the BIOS you should see if the HDD is detect,
If so, run HDD diagnostic test to check on your HDD.
Some BIOS has a built in simple HDD test, you can check from there.
else, your HDD could be faulty. the only way to test is to get a known working one to replace and see if the system detects it.
If your hdd has issues and wish to replace, I would recommend you to replace to a SSD for performance.
Esta resposta foi útil?
Pontuação 2
1 comentário:
try but i didnot work
por Compartilhar
Adicionar a sua resposta
Melissa será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 22
Ao todo: 3,601
