Ir para o conteúdo principal
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
How to turn off safe mode
Safe mode is on and cannot access some widgets
Esta é uma boa pergunta?
Pontuação 10
Adicionar um comentário
6 respostas
If you are trying to turn of safety mode you can go to the setting and then safari and then safety. You can also go to safari and go to the bottom to turn safety mode on or off. This also may work for Crome or google or any outher search engines. But on a laptop go to the settings on the web page and then go to safety
Esta resposta foi útil?
Pontuação 0
3 comentários:
What the !&&* are you talking about, there is no safari in settings on my rca 10 viking pro?
por
Sorry if that was not help full. Try to restart it by holding the power button and see if that helps.
http://www.tomsguide.com/forum/id-315383...
http://www.tomsguide.com/forum/id-303463...
por
There is no safari settings on on my RCA Viking ll Pro Tablet.
por
Pontuação 0
1 comentário:
how to turn off my safe mode
por
Has anybody figured out how to turn off this %#*@ safe mode with this RCA Atlas 10? Google Assistant I was told me to turn the tablet off and reset it that is not working. How did the %#*@ thing turn itself on all by itself anyway?
Pontuação 0
2 comentários:
yes see below
por
12.23.19 For anyone still needing an answer to this question “How do I get out of safe mode“ for my RCA Viking 10.1 here is the answer according to the Google assistant on my RCA Viking 10.1 And it WORKED !! :
Press & Hold the power button for a few seconds (With your tablet powered up and open)
Your tablet screen will open up with a small menu — press the RESTART option
Your tablet will be out of safe mode!
por
how can i get safe mode off of my tablet ?
Pontuação 0
1 comentário:
por
Pontuação 0
How to take off safety mode off of a Viking Pro tablet
Pontuação 0
Adicionar a sua resposta
Jean Forster será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 49
Ao todo: 4,908
