Ir para o conteúdo principal
Formato retangular / 16 GB de capacidade / Anunciado em 12 de setembro de 2012
Why it won't charge anymore?
It won't charge anymore. I have tried other wires. My iPhone charges. So I know it's the charging port.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
I would suspect that the iPod's battery is dead seeing as how this unit is probably 5 years old. iFixit doesn't sell the battery but a quick Google search should point you in the right direction. I would follow this guide for the replacement. Keep in mind that the battery is soldered in place so it will require some soldering skills to complete the repair.
Esta resposta foi útil?
Pontuação 2
I read somewhere to look inside the charging port to see if it's dirty. I poked in a toothpick, and a piece of lint came out. Problem solved!
Pontuação 1
2 comentários:
That's exactly what was the issue with mine! There was something in there. I put a toothpick in there and worked it out. Thanks for the tip!
por
I just fixed mine doing the same thing! There was a piece of lint or something in there!
por
Adicionar a sua resposta
Monica será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 44
Ao todo: 10,393
