Ir para o conteúdo principal
Guias de reparo e desmontagem para a cafeteira Jura (Capresso) da série Impressa J.
Espresso function has stopped working
When I press the single shot espresso button it grinds beans and starts to dispense then quits after only a couple of seconds. I have tried shutting off the machine, but nothing thus far has fixed the problem. It will still make a cup of coffee, but not espresso. Advice please.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It’s possibly working as intended. Do you know that for each button (1 esp, 2 esp, 1 coff, 2 coff) you can set up custom amount of water? Maybe your 1 esp button is setup to 10ml of water. So it does just that.
Check settings and reset as needed. RFTM for instructions how to
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Melinda Snodgrass será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 20
Ao todo: 388
