Ir para o conteúdo principal
Repair guides and support for the third-generation 5D, a DSLR camera released by Canon in 2012.
Replacing Mode Dial on Canon 5DMkIII
The button and metal face plate for the mode dial on my Canon 5DMkIII are missing. I lost them last December while running through the jungle, trying to keep up with a troop of chimpanzees. The dial itself is still intact and I've been able to change the mode by pressing a small pin into the button hole to unlock the dial.
I have a complete replacement dial/button/face plate in hand. Does anyone know how complicated it is to change this out or where I might find detailed instructions. . . . . .or at this point, should I just send it in to a professional for repairs (I have replaced components on a number of other cameras, with good success).
Thanks!
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
my canon 5d mark 3 brokened hot sho. if i no how can replese that
por
Hi Robert
I have this same problem with my 5dmkiii. Were you able to figure it out on your own?
por
Hi anyone found a place where they repair this issue?
por
Adicionar um comentário
2 respostas
If you have the mode dial cover you can replace it with a little lock tight super glue if it came with the 3m adhesive on the back it will fall off again. I had this same problem. Also you will find a small notch on the mode dial that helps you to align it properly. I hope this helps.
Esta resposta foi útil?
Pontuação 0
Bonjour
Voici la solution:
https://www.amazon.fr/vhbw-rechange-rota...
Je l'ai commandé et reçu.
La rondelle se colle avec un auto collant qui est fourni par le vendeur.
Bernard
rousseaubernard93@gmail.com
Pontuação 0
Adicionar a sua resposta
Robert Johnson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 15
Últimos 30 dias: 69
Ao todo: 3,886
