Ir para o conteúdo principal
Um disco rígido externo com interfaces USB 2.0 e Firewire 400/800. Disponível em capacidades entre 320 GB e 2 TB.
How do I replace the enclosure
I have a studio passbook and the hard disk is spinning, but it appears my enclosure needs to be replaced. How do I do this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi, what issues are you facing?
I think the internal height HDD is bigger than the usual 2.5 Inch drives.
So you dun have much choices to get a 3rd party enclosure.
Either you need to get from donor parts from ebay to replace.
I had read and heard some WD external drives need specially their boards for the drives to works, so it would be good for you to keep your old board, just in case.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Kyle “DJ XCEL” Rodriguez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 38
Ao todo: 2,183
