Ir para o conteúdo principal
Lançado em agosto de 2013. Identificado pelo número do modelo Z796C.
Editing my contact information
Hi, I have a ZTE Majesty Pro LTE Z798BL. My service provider is Tracfone/Safelink.
I am attempting to edit my contacts. When I touch the screen, I get a message that says I have disabled required permission. What permission? And how do I re-enable it?
Esta é uma boa pergunta?
Pontuação 9
4 comentários
I also have this problem and can not find an answer.
por
Yes help me remove message
por
ZTE, never again. I can't delete numbers I don't want anymore. I hate this Chinese built garbage!
por
My phone doesn't allow any contact to save
por
Adicionar um comentário
3 respostas
Pergunta mais útil
go into your setting and enable the permissions for your contacts..should be in application settings
Esta resposta foi útil?
Pontuação 5
4 comentários:
there are no permissions under settings, I have the same issue, there are no permissions under the apps either for this.
por
I had same problem on new phone and stumbled around for several days. Then happened across this and turned on all permissions in contact applications and the edit now works. Now I have to figure out which permissions I can turn off!
Phil Starr
por
Thank you Phil Starr, I turned on 'all permissions' in contacts an was able to edit my mom's ZTE cell. Thanks again!
por
How do I find the contact applications so I can all he permissions?
por
These Instructions were given me by a Engineering Student (who will be designing Cell Phones) at Walmart in a Cell Phone Kiosk. It was for the ZTE ZFIVE G
Home, Settings, Apps -
NOT apps as I was doing.
Then scroll down to Contacts…
Permissions then…
Storage - Slide the slider thing to the right.
Hope this helps - (I mentioned to her that non of these instructions were “intuitive” - who would think of it and not mentioned in the booklet either - errr! Please when designing cell phones make it intuitive. MHO
Pontuação 0
How to restore contacts
Update (09/01/2020)
It did not
Resore contacts
Pontuação 0
1 comentário:
On cell majestic. Zte
por
Adicionar a sua resposta
Elena Vaccaro será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Ao todo: 8,200
