Ir para o conteúdo principal
Guias de reparo e suporte para a segunda geração dos modelos SC, SL e SW da Saturn.
I have no low beams,
I have checked the fuses and replace all four headlight bulbs
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
skipkuchta, Recheck bulb sockets/wires/plugs/etc. for corrosion, clean if needed, reseat bulbs and try. Check all ground wiring in vicinity of lighting circuit, check for damage, clean connections and retighten. all looks good and still no go, possibly a bad headlight switch. Check the link below to possibly solve your low beam issue. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.justanswer.com/saturn/2yg84-9...
Esta resposta foi útil?
Pontuação 4
1 comentário:
@lpfaff1 We need you on meta.
por Compartilhar
skipkuchta besides the excellent answer provided by my esteemed colleague, you also want to check the relay. From the diagram it looks like the Saturn share the Fog lamp relay with the driving light. It is located in the under the hood junction block.
Imagem
Imagem
Pontuação 4
Adicionar a sua resposta
skipkuchta será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 2,137
