top screen shows image-but with green colouration
am fixing yet another ds lite (for yet another butterfingered son!) and the top screen is green, you can see all the images but only if you like green! the cable looks fine and so does the connector. I'm guessing this is definately a replace the LCD scenario, but on the off chance there is something else causing the problem, I'd love to hear it! Thanks.x
Esta pergunta é pertinente?
I have the same problem with my new dsi xl! The top screen on my dsi xl is more greenish than my regular dsi's screen. How can I fix this??
por Daniel Pedersen
I have no Idea my bottom screen is exactly as you described the top one is fine but it drives me crasy I can not take images or play games because my screen is discolored if you found any thing out pls tell me I would love to fix it thank you.
por Yackaxe
The same this happened to me but it's on a 3DS
por Nic
You can probably switch out the wifi module that will might the problem if not it’s a board-level problem and if it’s not that you might have to switch the connectors.
por Kymani Bailey
