Ir para o conteúdo principal
The tenth generation Ford F-Series is a line of pickup trucks that was produced by Ford Motor Company, it was sold from the 1997 to the 2004 model years.
83 Perguntas Visualizar todos
Need assistance cleaning intake manifold runner that is stuck open
Got codesP0102
P0705
P0708
P1518
P1151
P1131
Where should I begin?I've changed all plugs, cables,cleanened egr valve, and iac+outerside of throttle body(in front of flap)z (was told not to touch on inside of flap since it has a lubricant that cannot be removed?). I also sprayed the maf with maf sensor cleaner a few times and did not touch fibers on inside cause Ive also been told not to touch them since they are fragile few times.-Not sure if that was actually sufficiently. After all of that My truck still surged of control and stalls constantly when in low gear or idle as well as while in drive when gas is not being applied. I know this is alot of questions but I would greatly appreciate any help or direction as of where I should start first. Thank you
Esta é uma boa pergunta?
Pontuação 0
4 comentários
What kind of cleaners have you used to try to clean your manifold Runner
por
None yet-going to get bushings assuming they r why it's stuck open
por
I have this problem I'm trying to replace intake manifold runner control actuator clips don't know where to start please help
por
I have the same problem I'm trying to replace intake manifold Runner control actuator Clips I don't know where to start or where they are located please help me
por
Adicionar um comentário
1 resposta
Pergunta mais útil
I had identical issue. Ur gonna need a whopping $5 for some imrc bushings. Little plastic bushings for imrc rods behind your plenum. While ur at it though, you should just get the plenum gasket set and replace the gaskets while u have it off… you have to take the plenum off to get to the bushings. I'm betting you find one of the rods detached. There are great simple videos on YouTube for this. My teenage boys helped me with it and we had everything done from start to finish in 2
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Alex Stuve será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 1,760
