Need assistance cleaning intake manifold runner that is stuck open
Got codesP0102
P0705
P0708
P1518
P1151
P1131
Where should I begin?I've changed all plugs, cables,cleanened egr valve, and iac+outerside of throttle body(in front of flap)z (was told not to touch on inside of flap since it has a lubricant that cannot be removed?). I also sprayed the maf with maf sensor cleaner a few times and did not touch fibers on inside cause Ive also been told not to touch them since they are fragile few times.-Not sure if that was actually sufficiently. After all of that My truck still surged of control and stalls constantly when in low gear or idle as well as while in drive when gas is not being applied. I know this is alot of questions but I would greatly appreciate any help or direction as of where I should start first. Thank you
Esta é uma boa pergunta?
4 comentários
What kind of cleaners have you used to try to clean your manifold Runner
por Joel
None yet-going to get bushings assuming they r why it's stuck open
por Alex Stuve
I have this problem I'm trying to replace intake manifold runner control actuator clips don't know where to start please help
por Staci Crandall
I have the same problem I'm trying to replace intake manifold Runner control actuator Clips I don't know where to start or where they are located please help me
por Staci Crandall
