Ir para o conteúdo principal
The McCulloch MC1275 is a heavy-duty canister steam cleaner that uses ordinary water heated to over 200 degrees Fahrenheit to clean and sanitize a wide variety of surfaces.
27 Perguntas Visualizar todos
My steamer wont make steam
Whenever I press the steaming button, rather than steam, only water will come out in short drips. The device is plugged in, the indicator light is on, etc. We even followed the manual for setup to the letter and haven't poked around inside the machine at all. This machine is new, (Only a few hours old)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
nate michael, If you have followed all the correct operating/setup procedures in the manual(link below), the heating element may be defective. Since the steamer is so new return to place of purchase for replacement /refund. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.manualslib.com/manual/466149...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
nate michael será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 43
Duração total: 3,784
