Why does my screen look like this? Help please
After attempt of replacing sim card slot
i ended with a screen problem
(the only thing i did wrong was scratching some of the silicone gray thingy stuck to the Middle frame )
Can this be a problem rooting from the sim reader soldering?
is my screen dead now?
picture:
Imagem
https://www.hostingpics.net/viewer.php?i...
Part i damaged: https://www.dropbox.com/s/q3kzwz5pe4ozud...
Help please and thanks a lot
Update (06/16/2017)
hey guys ,
thank you for your answers
tried those methods .. it has been unsuccessful
the part that i damaged is here shown by an arrow
what is it? could it be the problem?
Imagem
Thank you soo much
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
Have you open the phone? Then look if the display cables are loose.
por
what claes said. also try cleaning all connections with 99% isopropyl alcohol. Also try a soft reset or battery pull.
por
Hey @oldturkey03 sorry :
here's another link
Thank you so much for trying to help
por
Adicionar um comentário
