Ir para o conteúdo principal
The HTC One Mini 2 was released in Europe, the Middle East, and Asia in May 2014. The HTC One Mini 2, model number M8MINx, features a single rear camera and 16 GB of storage. The HTC One Mini 2 is much like the HTC One M8 but smaller and less expensive.
20 Perguntas Visualizar todos
Why won't my phone turn on or charge?
Earlier, I was using my phone to look through my apps, and decided to charge my phone because I was going to go be with family. When I was about to leave, I took my phone off the charger and noticed it wouldn't turn on. I tried to hold the power button to see if it shut down on its own, or something of the sort. When it didn't, I tried to charge it. The charging light never turned on, so I was very confused.
I attempted to clean the charging port with a toothpick, in case if it was dirty or if something got stuck inside of it, like pocket lint. I tried using a different charging cord, but it wasn't working either. I would try to use my original charger, but its broken beyond repair (my dogs got ahold of it.) I also tried to reset the "charging logic" ( hold the power button and volume buttons for approx. two minutes) but nothing happened with that, either.
It should also be noted that my power button is broken in half, but still works. Half of it is stuck while the other half is perfectly functional. I've had the phone for almost three years, and the power button hasn't given me any trouble ever since being broken.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
My HTC phone power button stuck and want come unstuck my red led light want come on what should I do
por
Adicionar um comentário
1 resposta
Pergunta mais útil
It very likely needs a new battery. That should be all. Use this guide to replace it:
HTC One Mini 2 Battery Replacement
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Ashlyn Snyder será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,028
