Ir para o conteúdo principal
Parte da série 15 da linha de notebooks Inspiron da Dell, o modelo 3520 foi lançado em 18 de outubro de 2012. O Dell Inspiron 3520 é um notebook de 15 polegadas que é acessível e capaz de atender a uma variedade de necessidades.
Wifi problems after bios update
Hello.
I have a dell 3520: 6GB ram, 1TB hard drive, intel i5. A few months ago I had to update my bios... The problem became after I did it: At the very moment I started having issues with my wifi like it drops when I close the lid, and whenever I wake up the computer after it would take a looooooong time to wifi to start working, and actually, drivers disc won't detect the wifi card anymore. Moreover, the bluetooth doesn't work anymore. It doesn't shows up at all as installed in the devide manager.
I've been wondering if updating bios had something to do with it... So, I had thought to downgrade it to the previous version but then I came to find out that it is almost impossible (because I tried it and it was). So, any solutions to these?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
What i would do
Download the drivers from the manufacturers website using another device. Transfer using USB. Try to install and see what happens.
option2:
Find a cheap external wifi adapter and use that
option3:
Reinstall windows and see if it autodetects drivers
Hope one of these helps
Esta resposta foi útil?
Pontuação 0
3 comentários:
I've done that and it all stays the same!
por
even an external adapter?
por
Not with an external adapter. I tried installing the original so which was W8, then tried W7, and neither recognized wifi and bluetooth adapters. Actually, in order to make wifi work I had to search the driver in a weird czech page... Actually, bluetooth has never worked again since I made the bios update.
por
Adicionar a sua resposta
jrgg1994 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 837
