Why is my Dyson not working?
my Dyson inst working and i have no clue why? how much would it cost to be looked at and fixed and who can i take that to?
Esta é uma boa pergunta?
I would first suspect a bad battery. When you put it on the charger, does the light(s) glow? If you have access to another battery, try it. If that fails, the power button or wires to the battery have broke or failed. Use the below guide to check that out.
Esta resposta foi útil?
Just tell me where I can get it repaired? My cheap Shark is almost 3 yrs old & works fine.
My vacuum it works for a short period of time and stop. How can I fix it?
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 19
Ao todo: 3,133
2 comentários
Please give us a description of its symptoms. What will it do and won't do.
por mayer
only a year old-used maybe 10times-suction for 2 times , then I went back to using my $50 Shark-was going to throw it out then saw it was guaranteed for 2 yrs. Purchased 5/14/16 Where can I take it for repair? Most expensive vac I've ever had & never worked well.Tried my neighbor's first & his is old & still works fine. TY
por Judy Harrison
