Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Switching from PCI-e Flash storage to SSD
I am looking into purchasing a Macbook 2015 15''. I am very particular with the specs and price range and I want to know if there is anyway to get a macbook with PCI-E storage and in the future, upgrade it to SSD? I see many questions and answers on upgrading the storage but not changing it completely from PCI-E to SSD. If so, how hard, expensive is it to do?
Thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Lets see if I can unwind some of the confusion here. First PCIe is interface standard not what the device 'IS'.
In this case we are talking storage so your normal choices would be a traditional hard disk drive (HDD) or solid state drive (SSD). Here your system uses a blade type of SSD as the physical space is very limited.
The possible interfaces your system could have would be either SATA or PCIe depending on the age of your system. Here your system uses a custom PCIe 2.0 x4 interface (4 lanes).
So in a nutshell your system uses a PCIe SSD and your choices are limited as Apple designed their own blade SSD that while similar to the industry standard M.2 is not compatible!
For a frame of reference here is the only 3rd party that makes a compatible SSD for your system and their offerings: OWC - MacBook Pro with Retina Display 13" & 15" Late 2013, 2014, & 2015 SSD drives. Their drives are not as fast as the newer x4 Apple drives. So you might want to think if you need the larger drive now when you order your system or wait.
Esta resposta foi útil?
Pontuação 2
2 comentários:
How much slower is it than apples current drive? And what are the chances of them coming out with faster ones in the future for these models?
por
It's only a 2 lane (x2) Vs Apples 4 lane (x4). So its about half as fast.
As far as OWC coming out with something faster you'll need to ask them as I haven't a clue ;-{
por
Adicionar a sua resposta
Stefano Martinengo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 1,257
