Ir para o conteúdo principal
The Sony GTK-XB5 is a high powered home audio system with Bluetooth that was released in 2016. This audio system is available in black, red, and blue.
17 Perguntas Visualizar todos
Is it possible to add a battery
is it possible to add a battery?
Esta é uma boa pergunta?
Pontuação 4
1 comentário
There is now the XB60 and XB90 with in built battery
por
Adicionar um comentário
4 respostas
Pergunta mais útil
becki2000seb besides all the sarcasm here is a short answer. No. The power requirements for your Sony GTK-XB5 are to large for a battery.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Apologies if it was taken as a sarcastic answer. I am used to carrying around external batteries. They even make them for laptops. A first generation HyperJuice was a literal brick.
https://www.hypershop.com/products/hyper...
por
The power consumption of your battery is 30w.
You need something of massive capacity, something like this:
https://www.amazon.com/Portable-Generato...
Pontuação 2
3 comentários:
I don't know why this is funny, but it is.
por
True. I wish I could put an inbuilt battery some how
por
some bike battery could work?
por
I like reviving olde threads, especially ones with no decent answer! I found lithium scooter battery packs with built in BMS charging circuits integrated on Ebay. Wire in a charger for when the thing’s plugged in and you’re solid, long as you can also convert the electricity inside to amp the board, also :)
Pontuação 1
I used a 36 volt 2.6Ah battery for mine after the power supply in it die and it works great.
Pontuação 0
1 comentário:
I use a 36 volt Ryobi power tool battery because the power supply in it died.
por
Adicionar a sua resposta
becki2000seb será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 19
Ao todo: 9,069
