Ir para o conteúdo principal
Call Audio not working?
Hello, so this morning my phone was fine. I just got off of the phone with a friend and the audio and display was fine. I think as I got out of the car I dropped my phone and that's when the problems started.
My phone works completely fine all around except for when I go to make a call or when someone calls me. When I make a call, the display locks up and there's no sound coming out of the earpiece or when I put it on speaker. After I'm finally able to get my phone to end the call, I tested my music and audio on other applications and it works just fine.
The only thing that fixes it temporarily is knocking on the side of the phone to get the sound back and the display unfrozen. I've tried restarting my phone three times, pressing my thumb down gently on the top speaker in case of a loose connection, and exiting out of everything on my phone. Even FaceTime works but as far as just audio it will not cooperate.
If somebody can please have any idea what's going on and explain it would be much appreciated!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Is the phone on mute?
Esta resposta foi útil?
Pontuação 0
2 comentários:
I mean the call audio and the phone's
por
No, it isn't on mute
por
From what you described m, it sounds like you have damage to your front camera assembly flex cable which has you ear speaker connection on it. This also contact FaceTime audio. If this component fails, it can have some components work, such as camera but not audio. Or Siri not working. Try replacing this component to see if this works. Here is a guide and where to buy the parts. I would also replace the ear speaker mesh at the same time. Try this and let me know if it works or not.
iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement
Pontuação 0
Adicionar a sua resposta
jillybug125 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 75
