Ir para o conteúdo principal
Are iFixit replacment logic brds for iPhone 6 at risk of touch disease
probably a question for the iFixit crew.
I'm about to buy a new logic board for iPhone 6 as mine is suffering badly from touch disease, although I have never had the grey bar.
Just want to know if I buy a replacement logic board for an iphone 6 from iFixit if the touch IC's have been checked/re-soldered and so on.
Or could the same thing happen again.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Ok, so the board itself isn't at risk of touch disease, apples crappy frames for 6 and 6 plus are the issue. With that being said, iFixit does offer plates, to help keep the chips in place, as well as new soft covers, if you can't get the old one off and on without hassle
That's weird...can't seem to find em...and I asked for those new soft covers specifically!
Esta resposta foi útil?
Pontuação 4
2 comentários:
So, it the common currently accepted solution to resolving the touch issue to replace the logic board and then to place a plate on it? I know this is a year-old comment but I am having a hard time finding what the currently accepted solution is that doesn't involve rewetting the solder under the IC.
por
@kupajava The current best practice is to remove the Meson IC, place a micro-jumper on the M1 pad and reball Meson. No need for a plate. This is about as permanent a solution as you can get.
por
Theoretically, it could. However, iFixit stuff is great quality. If your motherboard is affected by touch disease, it is backed by their awesome lifetime warranty. I don't know exactly where there sourced, but if I had to guess I'd say they came right from some new iPhones. Utmost quality.
Hope this helps!
Pontuação 3
Adicionar a sua resposta
pep073 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 109
