Ir para o conteúdo principal
O guia de reparo do Mercedes W115 cobre ambos os modelos W114/W115, desde 200/200D, 220/220D, 230.4/230.6/240D, 250, 280, 300D e várias outras variantes, peruas (estates), cupês e sedãs de 1968 a 1976.
replacing driver side check strap
I need to replace the door check strap in my 76 300d W115. Took door panel off, but you can't get the check strap out without taking the entire window assembly out, it appears to me.
am I missing something on replaceing, and what is the proper procedure to removing the window etc.
need some advice on this.
thanks
Philip
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@yadkin2002, Philip, I do not believe/not positive the entire window should have to come out to change the door strap, you should have to remove the pin and bolts and may have to turn(manipulate) the old strap to remove from door cavity or possibly have to loosen front window guide/track. Just to add a little to OT post, the video links(not your exact model) but may help in the removal of check strap. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=m3_NggBa...
https://www.youtube.com/watch?v=R0U3VNbb...
https://mercedessource.com/store/mercede...
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Philip será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 19
Ao todo: 631
