Ir para o conteúdo principal
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
Water not coming through
Everything works but water not coming through to grounds
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Christina Inglett, Machine may require cleaning/descaling pg.26/27 in manual(1st link below), could be a bent/collapsed hose inside machine, pump may require priming or pump may be failing, Below find trouble manual, shooting guide, disassembly guide. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.partsguru.com/user/Rio%20Vapo...
Starbucks Barista Troubleshooting
Starbucks Barista Pump Replacement
Esta resposta foi útil?
Pontuação 1
Is water coming through the group head when the portafilter is not in place? If so, try switching to a coarser grind and see if you can get coffee to flow then. If that doesn't help then I'd make sure your coffee basket and group head screen aren't clogged, and if those are fine then you might have a failing pump.
Pontuação 0
Adicionar a sua resposta
Christina Inglett será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Ao todo: 3,690
