Ir para o conteúdo principal
Repair information and support for GE Profile Refrigerators.
Why is my freezer not at 0°?
My refrigerator model is GE Profile side-by -side PS123SGPA BS. Digital temperature panel in refrigerator section has a freezer temperature reading that hovers in 24°-26° range. Noticed it was warm few days ago.
Any idea what I should check or will this require a technician before buying a new fridge?
Esta é uma boa pergunta?
Pontuação 3
3 comentários
@ajultaylor what is the temperature in the fresh food (refrigerator)section?
por
It defrosts occasionally. Check it at different times.
por
Is there frost on the back of the freezer panel? If so , then the unit is not defrosting and would require replacing one or the following ... defrost thermostat , defrost heater and or control board
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@ajultaylor since we do not know yet what temperature your fresh food section is, follow the flowchart for whatever condition applies to your fridge. At this point I would think that the error is related to the main freezer thermistor, the damper or the control board. Let us know what you find out so we can further assist you.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Drew será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 1,916
