Portable television large bang
The warranty has just run out and the TV made a large bang and now does not work it's not a fuse as have tried a replacement
Samsung LT19C300E W/XU
Esta é uma boa pergunta?
Most likely one of the capacitors. There's several class action law suits on several of the models on the bad caps. You can Google your model. Here's just one example:
Esta resposta foi útil?
Carol Bradley I wonder if you are not looking at a Samsung Syncmaster monitor instead of a portable TV. First you should unplug your set and remove the back cover. Then take a look at the power board. As @mayer pointed out, there is a possibility that this is caused by a failed capacitor. There are also plenty of other possibilities that cannot be ruled out until you take a look at it. Take some good pictures of your boards as well as the data label of your monitor, and post those with your question. That will allow us to see what you see. Use this guide for that.
We have to many questions which these problems. Any way to find out which capacitors need to be changed? There are different repair kits being sold on Amazon.
@mayer mayer yes we do. One of the greatest challenges is to properly identify what device the OP has. This sounds like a Syncmaster Monitor; something of the T190 series.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 82
