Ir para o conteúdo principal
Processador Core Solo de 1,5, Core Duo de 1,66 ou 1,83, ou Core 2 Duo de 1,83 ou 2 GHz. Isto cobre os primeiros modelos de Mac mini baseados em Intel, de início de 2006 a meados de 2007.
Stuck at grey start up screen
Recently my mac mini will not boot up. The mini gets stuck at the grey start up screen with the apple logo. I tried to boot from OSX install disc no success. I tried pretty much everything but to no avail. I have unplugged it, tried to reset it, no success. I ran the hardware test which I could start and it came back ok. I started the mini in target mode and was able to use its hard drive to boot and start another mini . Anyone have any ideas?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
5 respostas
Solução escolhida
Here is a link to an Apple guide to clearing startup issues--hope it helps.
http://support.apple.com/kb/ts1417
Esta resposta foi útil?
Pontuação 2
Ok we all don't know if the failure is a HW or SW issue.
So do this:
Hold CMD + V for Verbose Mode during Startup - Where do the System hang? Write down the last three Lines.
When you don't see the spinning wheel then something with the HW need to be checked. I suggest an RAM or MLB failure. So check first Verbose Mode.
Bye
Pontuação 1
1 comentário:
hay, my macmini boots 4 to 5 times normal and then wont bootup up.. ..it only gous to blue screen.....what that coluld be? ram?
por
Try holding option at startup
Pontuação 0
Hi, I have this same problem, except the usb apple keyboard also doesn't respond..no caps light or anything..so I can't put it in certain modes.....this happened after a power outage in the area.
Pontuação 0
1 comentário:
Same here, anyone get an answer on this one?
por
the Problem is it is waiting for you to enter your password but you cannot see this on the gray screen
its a bug that has effected me in the last three updates simply type your password on the gray screen and your update will complete at least it did for me i have the mac mini 2011
Pontuação 0
Adicionar a sua resposta
Frank será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 31,738
