Why is my self balancing board not charging
I have had my board on the charger for couple days now when I have it on the charger it turns orange but other than that doesn't turn on without charger.
Esta é uma boa pergunta?
Camilyn VanDenBloomer, If this problem has just started since getting the new charger and you have a hard time plugging it into your balancing board, the charger could be wrong/defective. If possible try a different compatible charger. Check the charge port for any damage pin/pins, dust debri(pick/blow/clean out), test charger and battery with DVOM to see if charger and if battery does hold a charge(replace battery if not holding charge). Disassemble the board and check for ant loose/damaged/burnt wires/connections / components. The links below may be of some help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=cME9TB0X...
https://www.youtube.com/watch?v=dAWeGXF1...
Esta resposta foi útil?
Camilyn VanDenBloomer "i had ordered one off amazon and it turned on but only with a charger and just the orange light" it is possible that this is caused by a charger with the wrong specs. You do need to tell us what Voltage/Amperage the old charger had compared to the one you purchased. The other possibility is that the battery no longer holds a charge. For that you would have to consider replacing the battery.
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 1,356
3 comentários
What model is your board? What occurred before this? How long have you owned it? Any issues before this? Are you using the right charger?
por Cameron
i dont know the model the brand was uber round I have had it since December, 2015, and see well i broke the original charger last year this year i had ordered one off amazon and it turned on but only with a charger and just the orange light i have tried a reseting it but ididnt do anything different and thee can be a wrong charger? it fights in the charging spot and everything.
por Cami Vandenbloomer
Cami Vandenbloomer uber round or Uberboard?
por oldturkey03
