Ir para o conteúdo principal
O Asus Q501LA possui um processador Intel Core i5 4200U (1,60 GHz).
laptop has burn component
hi there i have an issue with my laptop,there is a burned component near the LCD connector and near the battery connector hope someone can send me a clear picture of it so that i can replace it manually
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
Can you send a picture of the burnt component? It would be easier to see the damage than to guess.
por
@haron09 post a couple of images of the component as well as where it is located on your board. Use this guide for that.
por
DrGlowire did you see the picture below
por
Adicionar um comentário
1 resposta
hi DrGlowire here is the picture
Imagem
Esta resposta foi útil?
Pontuação 0
1 comentário:
by the way this motherboard is for ASUS Q501L hope someone can reply and solve this issue,i need that that component so that i can replace it thanks.
por
Adicionar a sua resposta
haron medina será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 16
All Time: 476
