Ir para o conteúdo principal
The Toshiba Chromebook 2 laptop was released in 2014, and the model number is CB35-B3340. This Toshiba Chromebook is silver with a 13.3" high resolution screen.
20 Perguntas Visualizar todos
SSD replacement Toshiba Chromebook 2 2014
Hello
I would like to know if it's possible tu change the ssd on this model, i open the back of the pc and wondering if it is under the metal piece stuck to the proc ? i don't have termal pate at the moment so i dont want to take the risk; and wonder if someone know the answer ?
Thanks in advance
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Hey buddy. I am assuming you have the cb30 104 model like me? If so, I beleive you can pop open the chromebook and check. If the ssd is soldered to the motherboard, then there is your answer:)
por
Adicionar um comentário
2 respostas
Yes, this is feasible - you can find different manuals on the web, including this one
https://www.codedonut.com/chromebook/upg...
Esta resposta foi útil?
Pontuação 0
J'ai trouvé la réponse, sur le modèle 2014 le ssd est soudé sur la carte mère, il n'est donc pas possible de changer le disque dur.
Par contre une solution est d'acheté une clé usb 3.0, il en existe des très petites de 128 go sur amazon pour pas plus cher que 30 euros :
http://amzn.to/2sE7v5M
Pontuação 0
Adicionar a sua resposta
Raphael Abadie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 3,678
