Replaced Screen and Digitizer and Phone wont unlock.
I replaced the LCD Screen with Digitizer ( Ifixit) Phone powers up but I still can't slide the unlock soft key. Does not appear to be responsive to touch.
Esta é uma boa pergunta?
Either the digitizer cable is loose, or the touch IC went bad. In case one, simply re-seat the digitizer connector. Case two is a bit worse. I assume @refectio would know more about that.
Hope this helps!
Esta resposta foi útil?
Thanks George. You're right, it's probably just the digitizer connector although as a second option I would think it may be a bad screen. iFixit stands behind their products so if you can confirm that the screen is defective, they will replace it.
If re-seating the connectors doesn't work, then try to put back the old, cracked screen. If touch works on the old one, that eliminates the IC's and your problem is likely a bad screen.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 50
