Ir para o conteúdo principal
Guias de reparo e desmontagem para tablets da Asus com sistema operacional Windows.
120 Perguntas Visualizar todos
When I turn on the tablet only asus logo appears
When i turn on the tablet only asus logo appears,then nothing happens afterwards it stops there it is unable to continue load and go to the main screen . I keep on turning on and off the tablet but still it doesnt work . please help me thank you.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hi @dalida ,
What is the model number of the tablet?
por
ASUS MeMO Pad ME172V i think this one . @jayeff
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Sounds like your OS may be damaged, best bet is to factory reset it, you can use this guide from ASUS to fix it, try it and let us know what happens https://www.asus.com/US/support/FAQ/1006...
Esta resposta foi útil?
Pontuação 1
3 comentários:
Im sorry but im not that particular in terms of technology i dont know what those guides mean.
por
You don't need to be a pro at all. The instructions are very simple, click on the link and follow the instructions. Do it step by step and you can easily solve your situation. Let us know how it goes.
por
the boot menu doesnt show up after i press and hold to power button . it only turns on then off afterwards
por
Adicionar a sua resposta
ryandalida201 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 634
