Ir para o conteúdo principal
A terceira geração do tablet Samsung Galaxy com tela de 7 polegadas, anunciada em 24 de junho de 2013. O reparo deste dispositivo exige chaves e ferramentas de abertura. O dispositivo está disponível nas cores branco ou marrom-dourado com 8, 16 ou 32 GB de armazenamento, e inclui um slot microSD que pode comportar até 64 GB adicionais de memória.
forgot my pin number
how can I bypass lost pin number
Update (05/10/2017)
I have a Samsung galaxy note 3 model number is sm-t210 can I get in without loosing everything by doing a factory reset ????
Esta é uma boa pergunta?
Pontuação 20
11 comentários
Look at what i posted. I have multiple options on how to do it.
por
How to unlock a pin code from screen
por
i forgot my 4 digit pin to my samsung galaxy tab how can i know what is the password
por
How can I unlock my Samsung Galaxy tablet for my pin number
por
I forgot my 4-Digit pin to my Galaxy tablet how can I recover that without hard booting it and losing all my information
por
Exibir mais 6 comentários
Adicionar um comentário
7 respostas
Pergunta mais útil
https://android.gadgethacks.com/how-to/7...
There are a few different ways that do not involve data loss.
I hope this helps! If it did please hit accept answer!
Esta resposta foi útil?
Pontuação 6
The only way to bypass the unlock code is to factory reset your tablet, you will loose all your data though.
1. Power off your device.
2. Boot in recovery mode by pressing and holding Volume Up, Power Button and Home Button at the same time.
3. Release all buttons when the Samsung Galaxy Tab 3 Lite 7.0 screen flickers and in a few seconds the Recovery screen will appear.
A menu will appear use the volume up/down buttons to navigate to Factory Reset option and press the power button to accept, select OK/YES from the menu the proceeds to Factory Reset your tablet
Pontuação 4
3 comentários:
yes its very helpful for me
por
I cannot switch the tablet off without the pin number?
por
Not helpful because it doesn't work on every tablet I did all this and the pin is still there
por
I was able to fix mine using the pin # 1234.
Pontuação 4
It says draw of directions to unlock screen
Pontuação 1
2 comentários:
What I want to do is to unlock my Samsung Galaxy Tab
por
The tap says draw series of directions to unlock screen
por
More than a year now
Pontuação 0
2 comentários:
What does score 0 mean?
por
Am failing to understand score 0
por
Hey Luke you need to do a hard reset this may not work but try power off then push volume up and power button for about 4 sec. if it trys to power back on go 3 sec. what you want to do is get the robot on there and volume buttons up and down will guide you to reset enter will be power button good luck
Pontuação 0
Somebody gave this tablet the The Samsung Galaxy tablet 3 but the person does not remember the PIN number so how can I get in it to break the PIN number so I can open up the tablet
Pontuação 0
1 comentário:
How can I get into Samsung Galaxy tablet 3 when the person that gave it to my son doesn't remember the pin number which is a four number code how can I get into it to open it up and it won't allow me to do nothing
por
Adicionar a sua resposta
Luke Matthews será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 48,246
