Break invalid sim card
How can I break my Sim card for my LG tribute phone asked for a pin got the pin wrong now my Sim card says invalid need to fix ASAP how do i break the Sim card and restore it to its original format
Esta é uma boa pergunta?
You could restore the phone, that should do the trick....you'll lose all your data...
Turn on the phone by using the Power button.
Go to Settings and then to Backup & Reset.
Tap Factory data reset.
Choose Reset phone and select Erase everything.
Good job! The hard reset is done.
Esta resposta foi útil?
hi is someone can help me ?
my LG is appearing invalid sim card please i need a help
Hello, this problem causes when sim card slot doesn't registered in Network, my advice is call your network administration for sim card registration.
You should register sim slot by that IMEI code in your network operator.
how can i do that sir , cause am in Africa , Ghana
i really want to use this phone please sir , help me
Need help. Took sim card out and factory reset but now it won't read sim
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 19,719
