Ir para o conteúdo principal
Este notebook foi lançado em setembro de 2010, identificado pelo número de modelo Inspiron N5030 ou Inspiron 15. É um notebook totalmente preto com um logotipo da DELL no centro da tampa superior, um mouse pad com botões esquerdo e direito separados e um leitor de disco no lado direito do computador.
compatability of ram and cpu
I have a dell inspiron 15 N5030 with a Pentium T4500 dual core cpu and just bought 2x 4GB DDR3 1333 (CP3-10600) SODIMM chips for upgrading....I want to upgrade the cpu to the Pentium T9500 core duo cpu and want to know if it will support the same ram chips I bought? thank you very much for your time.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
Stephen -
According to Dell support site (http://downloads.dell.com/Manuals/all-pr...) Page 75, the N5030 will support up to 4GB of DDR3-1333, so you should be Ok.
Russ
Esta resposta foi útil?
Pontuação 2
3 comentários:
He has 8 Gb of ram that he got. So he wont be ok.
por Compartilhar
Ooops! Thanks.
por Compartilhar
A lot of time, they only test out to 4GB but, I have put in twice that amount and had it work with no problem. It will probably be fine.
por Compartilhar
Russ above said that it supports 4gb but i find that its very possible that it can support 8gb.
Give it a shot. As long as you have a 64 bit version of windows, you should see all 8gb. It wont hurt anything if you do not.
Hope this helps! If it did please hit the accept answer button!
Pontuação 1
thank you everybody for your input....yes I have a current 64 bit windows system....I am currently waiting for that 8GB worth of DDR3 1333 CP3-10600 chips cause I found out the stock t4500 is a 1333 system...am I right in assuming the stronger 9500 would support the same amount? and is it a 1333 cpu also? or more...I can't find the specs anywhere
Pontuação 0
3 comentários:
Instead of upgrading the CPU, you would get a better speed kick if you upgraded the hard drive to an SSD.
por Compartilhar
I know ssd drive is way faster than my current hard drive in my dell inspiron 15 N5030 that is running at speed of 5400rpm...I want to know if installing an hdd drive at 7200 will increase my speed more than upgrading the stock t4500 cpu to t9500 at an increase of 2.3ghz to 2.6?
one other factor you should know is that I have the ram maxed at 8gb dual channel and is running at a speed of 6-6-6-15 clocks/latency which I've been told is faster than the chips were designed for
por Compartilhar
Hello Stephen,
Have you got success with upgrading CPU and RAM memory?
por Compartilhar
Adicionar a sua resposta
Stephen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 20
Ao todo: 2,432
